andrew.k
- Jan 26, 2016
- Toronto, Canada
- Andrew
- 2016 V6 Fastback, Magnetic, 051A, MT, 3.55
Easy to do, thanks for a forum member for hosting the original PDF where I created this DIY from.
Removal
1. Jack up and Remove the wheel and tire.
2.
1. Remove the 2 brake pad pins.
2. Remove the brake pad spring retainer clip.
3. Remove the brake caliper pin bolt.
Torque: 22 lb.ft (30 Nm)
3. Compress the brake caliper pistons using a brake pad spreader tool.
4. Remove the brake pads.
1. NOTE: If installing new brake pads, make sure to install all new hardware and lubricant supplied with the
brake pad kit. Refer to the brake pad instruction sheet when applying lubricant.
To install, reverse the removal procedure.
2. Depress the brake pedal, check the brake fluid level in the brake fluid reservoir and top up as necessary
with brake fluid.
Removal
2.
with brake fluid.
