noGreta!
So far everything points to the DS. Did you replace with another stock one, aftermarket or custom-made?I had the exact same problem with my 21 when it was brand new. I ended up replacing the driveshaft and that totally cured the problem. The dealer wanted to perform a series of trials with hose clamps on the driveshaft and multiple road tests. I just ordered a new driveshaft and replaced it myself. I have very little trust in dealerships as I have worked in one for 15 years. What I found was that the factory driveshaft was not indexed correctly and simply repositioning on the rear flange probably would have fixed it. I have 6,000 miles since replaced and all is well. If you lay underneath and look at the rear differential flange it will have a yellow mark, make sure the weights do not align with that mark, you want the closest weight on the driveshaft to the rear diff flange to be 180 degrees off. I would start by checking that first.
