sk47
- Nov 12, 2020
- North Eastern TN
- Jeff
- Chevy Silverado & Nissan Sentra SE
Hello; Started this in the off topic area because it is not about a Mustang. I do figure there are some sharp minds here from the posts and threads I have read. The thread is going to be about an opportunity for me to learn more about the anti-theft system on my Nissan Sentra. May be some of the sharp minds on here can help.
I bought a 2001 Nissan Sentra SE new. It has the 2.0 liter engine. That car was up until a few days ago very reliable. I backed it out of my basement garage and moved it a short distance then shut it off so I could work on my truck and not have it blocked in in case I needed to go get parts.
A few hours later the Sentra will not start. I get out the OBDII code reader and hook it up. No stored codes at all. The car has never thrown a code and had never failed to start before.
The code it has are pending codes P1610 and P1612. Both turn out to be about the NATS system. That system is the anti-theft system. I guess some how that system was triggered. I was using one of the factory keys that came new with the car, not a replacement. In fact I have tried all three of the keys that came with the car.
The best guess I have so far is that the battery was too weak. It was the battery that came in the car in 2001, so around 18+ years old. It had been still starting the car even tho it did not spin so fast sometimes. I am guessing the low battery may have been a cause, but only a guess.
I put a new battery in today but this did not help other than it cranks faster. I looked up the NATS system and found a few things to try. One was to turn the key on without cranking for ten seconds, then off for five seconds, then on again and off again for three times. Did not work but that was with the old battery and I have not tried it with the new battery. ( will have to try that way)
I talked to a local mechanic. If it is the NATS system he cannot fix it. He suggested I try to lock and unlock the doors with the key and the key fob. I did so but did not help.
I am sure there is no spark but not so sure about the fuel pump. There is not a test valve on the fuel injection rail so I cannot attach my test gauge.
I did learn one thing today. That same mechanic suggested I set my OBDII reader to live data at the RPM setting and crank the engine. If it shows RPM while cranking then the crankshaft position sensor is good. If no RPM while cranking then that sensor is faulty. I had 750 RPM when cranking. That sensor was going to be the first thing replaced but now will not.
I called the Nissan dealership closest to me, about 40 miles away. They can check and fix it for $186 but I will have to have it towed. They gave me a local locksmith number. It seems that some locksmiths can work on these anti theft systems. He is to come by later today. On the phone his suspicion is about the sensor coil where the key is inserted may be bad. That is all so far.
I get that some will not wish to join in a thread about a Nissan. My guess is something may be learned about these anti-theft in general and ask for your patience. Thanks in advance to any who choose to participate.
