did yours get fixed what was the issue ?Not yet. I haven't had time to go to the dealer just yet. To much chaos going on. I am hoping maybe April.
Thanks.Yes it did. It was the tie rod. Went to a different dealer who looked at it and they found the issue.
According to dealer the noice is the Spring Insulator bearing on the passenger side. Annoying as hell will need to address it over winter.Also check the sway bar end links to ensure they arenāt loose, bent, or bad joint. I had one that was snug, but not torqued down that made clunk noises, especially under load cornering or variable surfaces. Drove me crazy trying to figure it out.
This is where iām at, i thought it was something in the suspension, but i put chassis ears on my car on the lateral links and found out the popping and rattling is coming from that.Ok, I finally got to the bottom of the noise problem after throwing parts at the car, parts that were not needed. I had a bad tie rod and lower ball joint. I hate trying to chase down a noise. Mines got progressively worst. However, Iām surprised the guys that did the alignment a few weeks ago did not catch the tie rod issues when they did the alignment. Mines went form a random chunking or rattling noise to a constant popping noise. I stop driving my car because it started sounding like something was going to break. Oh well, itās fixed now.
Good luck brother, I hope you get to the bottom of your noise issue.
