Cleaning Carbon Fiber Wheels
DFB5.0
Australia
Mustang GT Fastback
If you have to dial it down that low, then it isn't worth doing. I've heard of people using steam, but again, you don't want to run the risk of delamination.
Dialing it down that low would only be when using the CR spotless water demineralizer, which is used as the final rinse to prevent water spotting due to hard water.
kilobravo
Corpus Christi, TX
kilobravo.com
KB
'16 CT6, '18 SD, '20 GT 500
Sounds like the magic eraser is a good tool for it.
So I've read, Mark, I'll let y'all know..when I find the time to try one.
I did a poor job of explaining, Tom. I plan to use the pw just for stout rinsing, not stain removal..at first, and I'll start at 600psi while using the magic eraser. Once the initial cleaning is done, I'll test the unit on a stubborn spot and crank up the pressure a bit at a time to see if I can find the sweet spot that won't damage the coating but, does reduce or eliminate some or most of the stains.
kilobravo
Corpus Christi, TX
kilobravo.com
KB
Yep, I know the drill with the CRS unit well, D but out of precaution, I'm gonna start low and work up with the pressure on the wheels.
kilobravo
Corpus Christi, TX
kilobravo.com
KB
Have you tried mineral spirits?
That's a good suggestion, Brian but no, I didn't try MS the first time but I will certainly give it a shot. Kinda swamped with home and lawn-related chores at the moment but I'll get to the wheels Real Soon Now. Thanks for the idea.
