texag70
- Oct 15, 2014
- South Georgia
- 2015 Ruby Red GT Prem
Looking for rec for best car duster.
Just starting here in South Georgia with the pine pollen. Don't know how the stuff gets in my closed garage.Pollen season up there, too? Down here just south of Jacksonville, there are miles of pine tree farms. The pine pollen is horrible right now.
I used a california duster just the other day and it worked great on it.
That's what I've done and I still get a fine line of dust right at the end of each wipe. That said, it's not hard to spray that lightly and get it completely off with the micro towel.ill rather spray the car with a detail spray and use a clean soft microfiber towel to dust it off and give it some shine
Just got the Calif duster along with the smaller dash duster. Both work well. After I first used the car duster I noticed some streaks on my hood. I used a micro towel and they wiped right off. Then I read the duster info and it says this may happen as the duster is preloaded with a small amount of paraffin. Says it will wear off after a few uses. Glad I read that cause I couldn't figure out where these small streaks were coming from.I've used California dusters. Seem to work just fine.
Yes, that surprises a lot of people who do not read the card attached and just pull it out and wipe. I believe many have ended up in the trash because of this, but it does stop happening after a few uses. Just don't wash it with hot water or you'll remove the paraffin and it won't work very well.Just got the Calif duster along with the smaller dash duster. Both work well. After I first used the car duster I noticed some streaks on my hood. I used a micro towel and they wiped right off. Then I read the duster info and it says this may happen as the duster is preloaded with a small amount of paraffin. Says it will wear off after a few uses. Glad I read that cause I couldn't figure out where these small streaks were coming from.
