Brake bleeding question
sonicc
Mr. Bond
St. Louis
2015 Mustang GT
I have a '15 GT, non-pp, with 4 pots in the front and need to bleed the brakes.
I assume the order of calipers is the typical (furthest to closest from master cyl): rear right, rear left, front right, front left.
However, for the front calipers, do you start with the inner or outer screw first?
Thanks.
jacknifetoaswan
Charleston, SC
You always go from the outside to the inside, so yes, RR, LR, RF, LF. For the front calipers, do the outside, then the inside.
JR
Houston Kid
Houston, TX
I did my 6 piston yesterday after converting from the 4. I started with outer bleed screws on the fronts. Went well and brakes are working perfect.
