This is pretty much the reason for my questions. Ford invested a lot of time and money developing the GT350 and GT350R. The spring rates, ride heights, and swaybar stiffnesses were undoubtably selected after many different combinations we tried. With a set of well matched struts and shocks GT350 or GT350R springs and swaybars could be the basis for a really good handing GT.OP offers some good reasons to get your suspension setup from a single vendor so the pieces work together. These are multi-dimensional engineering problems, and throwing random parts at the car doesn't always lead to an optimal solution.
Oh... I thought we were suppose to make progressive springs for ride comfort that drop the rear an inch or more for that cool stance.Now I see a reason why BMR kept their rear drops at 1/2" and no more ;), @BMR Tech
You just have to keep making more stuff I want, don't you??Oh... I thought we were suppose to make progressive springs for ride comfort that drop the rear an inch or more for that cool stance.
I am working on a new set of springs to pair with GT350 Front and PP Rear Monos. You could say, I am on a mission.
And I thought that I had suspension issues. :lol: Pretty cool.I am in the process of installing base gt350 shocks and struts on my 2016 gt with Sportline springs. they bolt up perfectly fine. The front struts on the base 350 is mono tube and has a longer shaft. Also, the base 350 struts do not have the big dent on the strut body like the gt models. So running 350 struts with factory gt wheels you might rub on the strut housing. I am running 12mm spacers and Mrr 350 wheels without any rubbing issue and plenty of space.
Will see how the shocks and struts perform with the sportlines once completely installed.
The front 350 struts are identical to ford racing struts. Compression and rebound are also 99% same as the FRPP struts but the FRPP struts are twin tube.
Also, bump stops that came with the gt350 struts are same as the FRPP bump stops. Same part number.
Trying things out before I spend 3k+ on coilovers.
The Steeda struts and shocks are nice but they will not work well with sportlines. The car felt very lazy under load compression and it was uncontrollable because of the softer compression. Sportlines are more aggressive and also progressive rate. If you have linear springs Steeda shocks and struts would work well. Sportlines rely on more compression from shocks and struts that Steeda does not offer unless you are running linear springs.
Steeda on the left, gt350 in the middle, PP on the right
Gt350 installed with sportlines on my gt
Will the GT350 shocks atleast fit atop the LCA mount? I saw your comparison, and was thinking maybe a new upper shock mount that mounts higher could help with the travel.Nevemind. The bottom of the shock is not going to fit in the control arm.
It's the lower mounts that are the problem. The shaft is larger and the bolt spacing at the arm is wider. You'd need to grab GT350 control arms to use them.Will the GT350 shocks atleast fit atop the LCA mount? I saw your comparison, and was thinking maybe a new upper shock mount that mounts higher could help with the travel.
I'm just curious why you would go to such extents... not to disrespect, more to understand the goal and the expected outcome.It's the lower mounts that are the problem. The shaft is larger and the bolt spacing at the arm is wider. You'd need to grab GT350 control arms to use them.
http://www.mustang6g.com/forums/showpost.php?p=1362420&postcount=26
