Any reason not to go handling springs with FRPP track S&S?
SK GT
Houston
2015 GT(sold), 17 1LE
I recently got a good deal on some lightly used FRPP track shocks and struts and am wanting to pair them with some BMR performance or handling springs.
The car is a DD that does not see a track, but I'd like it to perform better around the streets than it does in stock non pp form.
Swaybars will also be changed, a front subframe brace added, and the BMR CB005 kit added on the rear.
Is there any reason not to go with the handling springs? I assume the track shocks and struts are up to the duty of handling them, no pun intended.
Thanks
SK
BmacIL
Enginerd
Naperville, IL
2015 Guard GT Base, M/T
They're the springs I want to go with paired with either the FRPP track dampers or Koni's. They'll be very well matched.
Competition Orange
Columbus, Ohio
2017 GT350
I'd get the performance with them personally based on the handling springs being built for Konis.
I have handling on stock PP, and from what I've read on the FRPP shocks/struts, they aren't that much better than the PP shock/struts.
From my experience with the handling springs, they need a good damper.
BobbyV
New Jersey
2015 Race Red Mustang GT 6MT
The FRPP track springs and shocks are very well matched and helped resolve the "floaty" feel of the stock PP suspension, without being harsh. I guess if you prefer linear springs (the FRPP springs are progressive) you would go with BMR, I believe several members here are very happy with that setup.
BmacIL
Enginerd
Naperville, IL
Perhaps Kelly [MENTION=9985]BMR Tech[/MENTION] can help with his experience on the FRPP and Konis with respect to the Handling springs.
SK GT
Houston
Thank you Evo. Seems like several of you guys are really happy with this setup. That is good to hear. I'd like to have Kelly [MENTION=9985]BMR Tech[/MENTION] weigh in also before I place an order.
Have progressive springs now on non pp shocks and struts. This should be a nice upgrade. Going linears this time around.
mumbles
ATL
Eric
'16 GT Prem OW
Thank you Evo. Seems like a several of you guys are really happy with this setup. That is good to hear. I'd like to have Kelly @BMR Tech weigh in also before I place an order.
MustangCollector has a thread where he has tried most of the combos available, and he is very happy with the FRPP S&S paired with Steeda Ultralite Linears... just a second perspective.
GT_Roadcourse_Newb
noob@cartech,prefer2drive
Rocklin, CA
2016 GT-PP::2000 Honda s2000::1996 Nissan Maxima
I really like the BMR's accentuation of a lowered nose, 1.2 inch front, .5 inch rear drops.
mumbles
ATL
Eric
'16 GT Prem OW
I understand, and honestly, I can go either way. Some cars "have" to have the nose dropped to get that "stance" and others don't... I feel like the S550 doesn't "have" to have the nose dropped to look good.
BMR Tech
Tampa, FL
www.bmrsuspension.com
Dion
2018 GT, 2010 GT500, 2019 F-150 5.0
Thanks
SK
SK, honestly - I would just do the SP080 Performance Springs.
The reason is because, I really catered those SP083 Handling springs for road course duty...and prefer that they be used with a Koni or Bilstein style damper on all 4 corners.
The Handling springs DO work with the FRPP Track kit, but just not as well as with a better damper. Evo above mentioned that he has them, and he has told me numerous times that he loves them with his dampers. I am not surprised, but he tends to be pretty aggressive with his car/combo and he may differ from others in that regard. He likes to push the envelope!
The SP080 work AWESOME with a good damper like the Track Kit, and a set of sway bars. You can get that "softer spring, bigger sway bar" set-up...which can be very effective when you are not on a racing tire...and it will also provide a better ride on a daily basis.
Any BMR spring combo will work.
Good luck!
SK GT
Houston
Sounds good to me. Thank you as always Kelly
