3/8 Spacers above my lower springs
spogshd
manchester uk
2016 convertible
I put the BMR lower springs on the rear however I don't like the tyre tucked up in the arch. If i use a 3/8 spacer how much will it rise at the arch, will it be 3/8 or will it be more. has anyone tried this.
BmacIL
Enginerd
Naperville, IL
2015 Guard GT Base, M/T
If you're referring to Steeda's spring spacers, they will raise the rear double the thickness of the spacer.
1/8" raises 1/4"
1/4" raises 1/2"
3/8" raises 3/4"
Performance nut
TX
2018 Mustang GT A10
1/8" raises 1/4"
1/4" raises 1/2"
3/8" raises 3/4"
Out of curiosity, how does that work out? It is just the one spacer on top of the springs, right (opposed to a spacer on top and bottom)? Not sure why a 1/4" thick spacer would raise a car 1/2".
Not saying you are wrong, more along the lines of trying to understand why that happens. :shrug:
BmacIL
Enginerd
Naperville, IL
It's because of the motion ratio of wheel to spring. A 1/4" change at the spring results in a 1/2" change at the wheel. This is also why the rear spring rates are so much higher than the front.
Wheel rate = (spring rate)*(motion ratio^2)
spogshd
spogshd
manchester uk
2016 convertible
Thanks Bmac so it will still be lower than stock but not by much.
That's what I'm after. I've gone 38mm offset with 295x35x20 on 10 1/2 rims
I would have been better using 275 s as when it bottoms out it just catch the archs on the very top of the
Tyre wall.
I like a bit of poke and to see a gap maybe I should have just left the stock springs in but I've
Swapped everything to BMR .
BmacIL
Enginerd
Naperville, IL
Tyre wall.
It will be higher in the rear than stock if you have BMR springs and 3/8" spacers. If you want to be at stock height, use 1/4" spacers. If you want in between where you are now and stock, use 1/8".
