'22 Mach 1 Front Bumper Turn Signal Harness
Top Fuel Friday
Kentucky
Adrian
'22 Dark Matter Gray Metalic Mach 1
Benny,
Doing a little troubleshooting - are there different part #'s for the left and right harness for the front turn signals on a mach 1?
I ordered a turn signal kit, that was validated to work with several other forum members, but won't plug into my factory harness. Made me think that there could be a revised harness where the pin size is different between the main turn signal bulb and the bumper harness. My connector (bottom) has three narrow pins vs the Diode Dynamic connector with 3 wider pins. Neither side will plug in.
Wanted to see if there were two part numbers, I could order a L and R harness with the wider pins so the diode dynamics kit would correctly plug and play.
LevittownFordParts
Worldwide
Benny
S550's!
Hi,
Send me your VIN so we can hopefully establish what you have then go from there
- Benny
Top Fuel Friday
Top Fuel Friday
Kentucky
Adrian
Thank you, figured it out, the pins from diode dynamics all needed to be bent Down to down to fit connector. After that adjustment all was well. Thank you
