- Oct 7, 2014
- California
- Website
- www.modularmotorsportsracing.com
- Worlds Fastest & Only 5 second Coyote
MMR is pleased to release our newest HOM kit (head oiling mod) for 2018+ 5.0 Coyote Engines!
The MMR cylinder head oiling modification ( oil balance lines ) joins the left and right cylinder head together with the MMR Balance tube and fittings and balances bank to bank pressure and flow. In the event that the VERY small factory pressure orifice is clogged the head will continue to receive oil due to the MMR balance tube. MMR has seen hundreds of cylinder heads ruined because of oil starvation, this simple, easy to install mod will guarantee that your cylinder heads always remain lubricated along with perfectly balanced pressure.
MMR's 2018-2023 Kit replaces the factory "TAP in" Freeze plugs with high quality, precision fit stainless steel Fittings.
THIS IS A MUST FOR ALL PERFORMANCE APPLICATIONS!!
MMR also suggests the head cooling mod (HCM) for all performance applications
NOTE: While we have seen some copies of the MMR product it should be noted that those kits using 2 hoses to join all of the lifter bores together are 100% unnecessary, they add cost, installation complexity, increased points for failure and leaking, increased weight and redundancy, this is because the lifter bores are already joined at the front of the cylinder head via a machined tunnel in the casting making a second hose completely useless.
Includes:
Stainless Steel MMR Cylinder head Fittings
Black Teflon Motorsports Hose (high pressure and temperature)
Loctite Sealing/Retaining compound
Fits:
2018-23 Mustang GT
2018-23 F150 w/5.0L
ORDER NOW!! https://www.modularmotorsportsracin...e=product_info&cPath=4_30_49&products_id=1517
Includes:
Fits:
2018-23 Mustang GT
2018-23 F150 w/5.0L
