Who wants an electric parking brake... probably the lamest part of newer cars :shrug:
You don't need more low-end torque if you're in the right gear, which is the lowest possible gear
And a tall 6th is the only thing that doesnt make this thing a truck on gas.. not to mention 5th goes to 170, 0 need for an accelerating 6th gear.
Clutch spring is already light as F from the factory, they should make it stiffer like the Steeda spring does, or more similar to the Corvettes clutch which is heavy and very linear/easy to use.
Better audio system definitely would be a nice touch, as a premium standalone option perhaps
I doubt there's much of a weight difference overall, since an EPAS rack & pinion unit with its bulky case containing a fairly powerful electric motor and some gearing is going to be considerably heavier than an HPAS r&p.Unfortunately hydraulic steering is becoming extinct. If you think about it, it's kind of counterproductive to ask for 100-200lb weight reduction and more power, then add the weight of hyd steering. A pump, hoses, and cooler. Not to mention how much power is consumed by running a pump constantly when it's really not needed 95% of the time
My wife's Subie has it. Needless complexity, no ability to modulate how firmly it gets applied, not useful for emergency braking . . . no, you really don't want this.Electric parking brake
