1BadAss16CS
Light'em up!
- Dec 7, 2015
- Chicago Burbs
- Mike
- 2016 Deep Impact Blue CS
Listing for a friend. Looking for 20k OBO. Dyno sheet available upon request. PM me for contact info. Thanks
Most of the Hard work is done by AVS Fabrication, Al Verschave. Al's shop was previously out of Orland Park, IL now out of Oceanside, CA.
Car is located in IL
Pics located here: https://drive.google.com/drive/folders/1J2_K9juFNEBifQUYwSN2_1a3-zQqZUBD
MODS:
TH400 Trans w/3500 stall
JW Bellhousing
Trans Cooler
Custom Trans Cross member
Torque Box Reinforcement
Custom Aluminum Delete Panel form Factory Shifter Hole
Trans Brake
8 pt. Chromoly Cage
Sub Frame Connectors
(2) 5 pt seat belts
Line Lock
Rear Kill Switch
2003 Terminator
Ford Racing Valve Covers
Bore and Stroke 90.2x90
2.2 Whipple Super Charger with 2.875 pulley
Custom Ground Comp Cams (I can not remember the details of these)
Moroso Oil Pan
SLP Long Tube Headders
SLP Catted X Pipe with Removable Cats
SLP Loudmouth Exhaust
Kenne Bell Boost A Pump
Kenne Bell Boost A Spark
Custom Tune From Bob Kurgan
Factory 8.8 Rear End
3.73 rear gear
31 Spline Axels
Auburn ECTED Electrically Controlled Diff- 31 Spline
Ford Racing Diff Cover
3" Chromoly Driveshaft
295 55 rear tires
Various Suspension Upgrades:
QA1 Tubular K Member
QA1 Control Arms
Steeda Front Swaybar
Steeda Bump Steer Kit
Steeda Drag Pak with Drag Springs
Steeda Lower Control Arms
QA1 and Tokico Adjustable Shocks
MODS:
JW Bellhousing
Trans Cooler
Trans Brake
8 pt. Chromoly Cage
(2) 5 pt seat belts
Line Lock
Rear Kill Switch
2003 Terminator
Moroso Oil Pan
3.73 rear gear
31 Spline Axels
295 55 rear tires
QA1 Control Arms
