18x8.5 Racestar Recluse 95 Fitment help
cobraman800
AZ
2019 Race Red Mustang GT
Hi, I just bought 18x8.5 Racestar recluse 95's for my 2019 GT PP1 and it won't clear the front brembo brake. Does anyone know if there is a specific wheel spacer or mod that I can do that might work to get these to fit? I already mounted the tire to the wheel so it is to late to return them now.
Thanks
djcodeman
Austin, Tx
2015 GT roush SC
Wow, I was about to order these too... I would imagine a 25mm spacer would clear it?
cobraman800
cobraman800
AZ
Wheel spacers didn't work either. Don't get these wheels or wheels this size unless you want to change your front brake set up. I ended up buying baer racing brakes to make this set up fit and I didn't like those brakes since they were so small and also were very squeaky. So I sold this set up and got a whole new brake kit and 20 inch wheels.
djcodeman
Austin, Tx
2015 GT roush SC
What about running a 18x10.5 square setup with the wheels.... I know the offset is 50, so less than ideal and could be corrected with a spacer but.. it could work right?
cobraman800
cobraman800
AZ
I am not sure about the 10.5 for the front. The one's that I had were the 18x8.5. The issue that I had was the caliber was just to large and it started digging into the inside of the wheel, so I think it would do the same think regardless of the width. I wouldn't take the risk since it will likely cost you a restocking fee if you have to ship them back. I would find another set up unless you are willing to go with smaller brakes and get rid of your brembo's.
djcodeman
Austin, Tx
2015 GT roush SC
I spoke to someone at race star yesterday who thought they would fit as long as it would clear the 15 inch rotor.. I guess I have more researching to do...
djcodeman
Austin, Tx
2015 GT roush SC
Upon more inquires, the barrel design of the racestar recluse will not clear the brembos... seems I will end up with a mismatching set, and put some 19s up front. There are a few similar options visually, just up to finding the most cost effective solution at this point....
