z6cyl
My dealer failed to adjust the tire pressure on delivery of my new Mustang. The door sill states 32psi recommended for my tires/wheels, so I adjusted the tires down from 45psi to 32psi.
After a bit of settling it seems like they are now at 31psi on 3 corners and 32psi on the last corner. Should I try to get them back up to the 32psi on the 3 corners or call it good?
Also what will happen to the tire pressure in the winter? Right now its summer in CO, and I adjusted the tires while they were "cold" probably room temperature or slightly warmer in the garage. In the winter it will be below freezing. Will I need to add some air to the tires as it gets colder (but before winter tires) or will the psi change not be that great?
These are epic noob questions but I've never cared about a car this much so I want to make sure its done right.
