JLsounds
One of my techs and myself have started the audio section of my Mustang build. I have an actual build thread going on in the member build section. Being that this audio related, I figured I would share it with people here in case they don't go into the member build sections. This build will be based around the factory 8" Sync 2 in my vehicle. The car is outfitted with the second level audio system. So in other words, it does not have the factory woofer or the factory coaxial speakers in the rear deck. I own a mobile electronics shop so this is being built as one of our demo vehicles. This build will take about a month and I will post pics as we make progress. As you will see throughout the build we are keeping vehicle mods to a minimum and we are working to keep the weight down as far as possible. There will be some areas that weight is going to happen for the audio system to perform. There aren't a lot of options around this if we want the system to perform. You will see that the enclosure is where most of the weight will be. We are big on fidelity and sound quality at my shop and that is the main mission with this system. I'd be more than happy to answer questions if you have them. Hopefully this will help some of you guys that might be tackling your own installs or having a professional do it. I have seen some good info being given out in the audio section of this forum and some bad, so I hope I can help out where needed.
Here is most of the gear going into the vehicle. The woofers are not here. They will consist of two JL Audio 10w6 10"
As with all of our high end builds we started by sound deadening the entire vehicle. Total weight added is right at 50 pounds
sound deadening under the carpet
this material is a closed cell foam carpet pad that we put over the top of the mat material. It kills all low frequency road noise
complete shot of the driver's floor board done
Running the power wire through the car requires the removal of the inner fender well on the passenger side. Once done there is large grommet the wire can go through
inside the fender well. I/we use factory TESSA tape to tie everything together. TESSA tape is a cloth or nylon style tape. Which to use depends on if you are using it on the exterior or interior of the vehicle
0awg power wire ran along the passenger floor board. These cars actually have more room for running wire than I expected. The back of the vehicle comes apart very easily as well.
This is what I have done for now. I will post pics as we make progress.
