David@FFtec
- Dec 21, 2014
- SF Bay Area
- David
- 1992 Eagle Talon, Porsche 944 Turbo
We had our trans off last week to do a clutch upgrade so I thought I'd share some pics and info about the EcoBoost clutch system.
First, it uses a hydraulic throw out bearing like the previous Mustang. It's a nice system with light pedal pressure and minimal friction. It has a couple of quirks; 1. Since the slave cylinder is mounted in the bellhousing the line must be disconnected when you remove the trans. 2. There's no bleed fitting on the slave cylinder so it requires a vacuum fitting to purge out any bubbles after it's reconnected.
You'll also notice the input shaft on the trans is upgraded on the new Ecoboost. Older Mustangs used a coarse 10 spline shaft that was prone to twisting at high torque levels. Ford was wise and gave the EcoBoost the stronger 23 spline shaft.
The shifter mount is a nice upgrade over the older version. As you can see it uses a rigid cast aluminum truss style construction for a direct connection to the trans. The shifter has a nice, direct feel. It only takes a couple of aftermarket bushings to firm up the shifting feel even more.
The pressure plate is a little different. It has a self adjusting mechanism inside the cover which compensates for the disc thinning as it wears down. The main benefit of this feature is that the pedal pressure remains consistent over the entire life of the clutch. Here's a close look at the self adjusting mechanism in the pressure plate.
The flywheel is a heavy dual mass flywheel. It weighs 30.2 pounds! Like other dual mass flywheels it should not be resurfaced when replacing the clutch.
We installed an upgraded 6 puck friction disc on our '15 EB.
Yes that's a Borg-Warner twin scroll T4 EFR turbo in the upper right corner of that pic!
