Almost certainly not.Looking for snow tires and I have a set of 18 inch rims wondering if they will work
Unless they are expensive and designed with thin wall, they will not. There is no way in heck a "normal" 18 inch rim will fit.
In comparison to budget 19" wheels you can get, they are kind of expensive.Neither of these are very expensive. What are you calling 'normal wheels'?
Those are absolutely expensive.Neither of these are very expensive. What are you calling 'normal wheels'?
That's because forgestars are higher quality than these "budget" wheels. Budget wheels are typically cast and weigh more. From a performance stand point, this is a no-noIn comparison to budget 19" wheels you can get, they are kind of expensive.
Except the question is specifically asking about getting snow tires, so "performance" is hardly the main consideration. It's that 19" snow tires are WAY more expensive.That's because forgestars are higher quality than these "budget" wheels. Budget wheels are typically cast and weigh more. From a performance stand point, this is a no-no
Tirerack shows me I can get a set of winter tires and wheels mounted with TPMS for my Mustang for $1450 or so. That's cheaper than any winter beater I could potentially buy (and have to pay to insure and register, etc.).If the car has the performance package, as the OP alluded to, then performance should be a concern per the use of the vehicle. If cheap transportation in snow is the requirement, there are cheaper and safer options than putting snow tires on a Mustang.
