Is there a power lead in trunk?
Just wondering if there is any way to jump off a power lead in trunk region (if it exists) instead of having to fish wire from trunk up to front of vehicle...
yomamma219
Raleigh, North Carolina
2016 Mustang EB Premium Pony Pack "4HORSEMEN"
I haven't seen anything to this extent. I've only been keeping an eye out for an easy sub solution for the car though. If you come up with something easy let us know!
wildcatgoal
@sirboom_photography
TBD
No, there's not. There isn't a sufficient power lead for any respectable aftermarket amplifier in ANY car that I've come across in 8 years of installing high-end car stereos. Remote turn on lead... sure.
MSMStannyl
Baltimore, MD
2015 Mustang GT Premium - Triple Yellow
Yeh, that's definitely a "no". There's no way the tiny gauge wiring that's running through there could support the needs of a sub amplifier as well as whatever it was meant for. You'd prob blow through the fuse of anything you connected to. You definitely want to run a proper, dedicated power wire with the proper overcurrent protection.
mumbles
ATL
Eric
'16 GT Prem OW
You mean I cannot hook up my 4 gauge to my tail lights? Who knew? :shrug:
Crap! All my upgrade plans are out the window! :)
donmcgowen
Chicago
2015 Mustang GT, D1 Procharger Stage 2
You want to power an amp from the trunk, or do you need an amp turn on signal in the trunk. I talked into a hot wire going to the trunk lid. Probably for the backup camera. That turns on my amp but doesn't power it.
z06psi
Evans, GA.
Andrew
The pot stirrer
