crazyfish
- Dec 10, 2015
- Bolingbrook IL
- '16 GT350 & '14 GT Track Car
I know I am not the only one out there so I figured this would be a good thread to start.
Since the gt350 stereo is mediocre at best. Who is going to upgrade and what is in store and what components.
Here is what I am doing. I am using an Audio Control DQ61 signal processor/equalizer to get signal from stock stereo.
I am putting 3 way components in front of car. I am going to put Mid Woofers in stock door location. Put midrange in dash over the center gauges and tweeters in stock locations.
In rear run 2 way components with mid woofer in stock shelf and tweeters somewhere in rear side panels.
For bass ill run 2 12" subs in custom enclosure.
For power running 2 amps total. Front and rear about 100W RMS per channel x4 and subs running about 500W RMS in 1 channel 2 ohm load.
Components, Audio Control, Hertz HSK 165.3 upfront and Alpine SR 2 way component rear, Alpine PDX amp, subs soundstream.
System should rock.
Let us all know what you got planned. Want to compare and share info. thanks
System should rock.
