Blk2015GT
The Shelby arent the be all of half shafts by any means. They are only a LITTLE stronger than the GT ones; nowhere near the Ford Racing or other aftermarket strength. If you aren't running big horsepower then stock GT ones will do just fine. People are only replacing them running big hp and stickies because they snap drag racing. Otherwise there is no reason to replace them.
If you're running boost the 350 ones won't help much since they still will break as they aren't built for big hp, and if you're not running boost they're frankly a waste of money since they GT ones hold a good amount of horsepower. People are running the stocks with mild boost to 550-600hp just fine.
The GT350s will give you little to no performance advantage absent running big hp and stickies racing, and are frankly a waste of $550 (with the C-clips) plus labor. But hey your money.
And unless you know something thousands of other members don't, no info has been released on the half shaft length or splines in the GT350. Tons of assumptions at this point any GT350 parts will fit at this point besides the steering wheel which is confirmed.
