TinMannequin
The temperature reading next to the clock is constantly stuck at 50 degrees. The outside temperature is above 80 degrees so there is definitely a problem. I can't even figure out where the sensor is located to check for a loose connection. Anyone out there know where it is at on the car or do you know how to fix this issue?
