2015+ S550 Mustang Forum (GT, GT350, GT500, Mach 1, Ecoboost) - Mustang6G.com 33 - RDP Store - 1
Homepage Wiki MOTM Register Search Today's Posts Mark Forums Read Ford Bronco Forum Calendar Garage
Go Back   2015+ S550 Mustang Forum (GT, GT350, GT500, Mach 1, Ecoboost) - Mustang6G.com > Technical Subforums > Suspension, Brakes & Chassis
Suspension, Brakes & Chassis Everything related to S550 Mustang suspension, brakes and chassis.
User Tag List
Reply
Thread Tools Search this Thread Display Modes
Old 10-14-2017, 02:15 PM   #1
Seatown Stang
HereWeGo
Seatown Stang's Avatar
Drives: 2015 Mustang GT Premium
Thanked: 133 Times in 75 Posts
iTrader Score: 2 reviews
Differential noise with steeda diff bushings
Hey guys wondering if anybody has a fix, other than removing the differential bushings, to reduce or get rid of the differential whine after installing the steeda differential bushings?
__________________
Mods: Lund Tuned, AWE Switchpath Catback, AirRaid CAI, Eibach Pro-kit Springs, 3.55 gears, Ferrada FR2 20x9 and 20x10.5, APR Splitter, RTR front Grill, Steeda subframe braces, Steeda differential bushings, Steeda IRS bushing support, BMR Vertical Links, BMR Lower Control Arm Bearing kit (BK055), BMR Front subframe brace, BMR Rear Toe Links, PP Rear Sway Bar.
Check Out My YouTube Channel
YouTube: https://www.youtube.com/c/herewegonow
Join the FB Community: https://www.facebook.com/youtubeherewego
Instagram: https://www.instagram.com/herewegoyt/?hl=en
Seatown Stang is offline   Reply With Quote
Old 10-15-2017, 11:51 AM   #2
VinnAY
Drives: 15 GT/PP
Thanked: 215 Times in 146 Posts
iTrader Score: 0 reviews
Which bushing did you use the Red or Black? Judging on your mods I would be awfully surprised that you'd find some gear whine bothersome.
VinnAY is offline   Reply With Quote
Old 10-15-2017, 11:55 AM   #3
Seatown Stang
HereWeGo
Quote:
Used the red ones....I was surprised too but once I'm up to 70 or so it gets pretty noticable.
__________________
Old 10-15-2017, 12:33 PM   #4
5.oh
Drives: 2016 Oxford white 5.0
Thanked: 93 Times in 74 Posts
I have the black ones installed and dont really hear them that much. with the radio off i can hear some whine.
5.oh is offline   Reply With Quote
Old 10-15-2017, 04:17 PM   #5
armykyle1
armykyle1's Avatar
Drives: 2015 GT premium PP
Thanked: 162 Times in 131 Posts
I went to a heavier oil, that helped a little bit.
__________________
2015 GTPP Premium. MBRP long tubes. Custom 3" exhaust and magnaflow mufflers. Steeda CAI, GT350 mani and Lund tune.
armykyle1 is offline   Reply With Quote
Old 10-17-2017, 02:20 PM   #6
VinnAY
Drives: 15 GT/PP
I ran the black ones and I can barely hear it on the hiway if I shut the radio off but my hearing is damaged already.
Old 10-17-2017, 02:25 PM   #7
1badrz28
1badrz28's Avatar
Drives: 2017
Thanked: 54 Times in 42 Posts
I have black, and notice nothing.
__________________
2017 Mustang GT- Oxford White, 401A, Auto, Black Out, 3.55 gears, Holley Sniper, Lund tuned E85, 47lb injectors, , 170 degree t-stat, 3in. Corsa Sport, 1 7/8 headers, PMAS Intake, BMR Lock Out, Black Steeda Diff Bushings, 20% tint. "No such thing as NVH in a Mustang".
1badrz28 is offline   Reply With Quote
Old 10-17-2017, 02:43 PM   #8
Seatown Stang
HereWeGo
Quote:
Weird mine is pretty bad above 65 70
__________________
Old 10-17-2017, 02:50 PM   #9
1badrz28
1badrz28's Avatar
Drives: 2017
Quote:
It's possible hat the lash was set up incorrectly from the factory. Either take it in or have a rear-end specialist re-adjust the lash.
__________________
Old 10-17-2017, 03:10 PM   #10
Seatown Stang
HereWeGo
Hmmm never thought of that but great point. Wonder how much that would cost to correct...I'll give my shop a call to diagnose and correct it if need be.
__________________
Old 10-17-2017, 03:25 PM   #11
Jeff_oddo
Jeff_oddo's Avatar
Thanked: 121 Times in 98 Posts
I have the BMR lockout bushings and they make the rear end whine real bad. I’m switching to the Steeda red ones because I heard someone say they aren’t as bad with NVH. Ehhhh oh well.
__________________
2015 GT Premium A6, 3:15 gears, Paxton Novi 2200SL, Tial Q 50mm BOV, Kooks headers w/ Green hi-flow cats, MMR Oil Pump Gears and Crank Sprocket, ATI Super Damper, Polyurethane Motor Mounts, ID1000's, JPC Triple Pump return style fuel system, JLT Intake, 170* thermostat, UPR oil separater, DSS Carbon Fiber Driveshaft, Steeda Billet shock mounts, BMR Vertical Links, BMR Diff Lockout Bushings, Ford Racing Halfshafts, BMR Cradle Support, Kooks full 3" Exhaust, Lund Tuned 716HP/569TQ on 93
Jeff_oddo is offline   Reply With Quote
Old 10-17-2017, 03:47 PM   #12
Seatown Stang
HereWeGo
Hmmm I have the Steeda IRS support bushings. wonder if they could be causing the issue...
__________________
Old 10-17-2017, 03:51 PM   #13
DennisP
Thanked: 21 Times in 15 Posts
I have the red diff lockout kit from BMR and I have diff whine (more like a whistle in my case) from about low 50s to low 60s mph.
__________________
[2015 Mustang GT Premium 6-spd Auto 50th Anniversary Trim] [Ingot Silver]
[Roush AB + Mishimoto H-Pipe] [Diode Dynamics Interior LED Conversion- Red / Reverse Light]
[Ford Track Handling Pack Shocks, Springs, Sway Bars, Knuckle to Toe Link Bearings] [Ford Cowl and Strut Tower Braces] [BMR CB005 / BK051] [J&M Spherical Vertical Links] [Steeda LCA Bearings / Rear Shock Mounts / Shims for CB005] [Energy Suspension front lateral locks]
DennisP is offline   Reply With Quote
Old 10-17-2017, 03:54 PM   #14
wildcatgoal
@sirboom_photography
wildcatgoal's Avatar
Drives: '16 GT PP DIB
Thanked: 1,731 Times in 1,258 Posts
I have aluminum inserts (Steeda's), the full suite of Steeda parts for the IRS, an aluminum driveshaft, a transmission-mounted MGW shifter, and Steeda engine mounts. I get some whine, I get some more engine noise, but nothing that bothers me and nothing that anyone else in my car (who also owns a Mustang) has ever really spoken up about. I suspect you'll get used to it and tune it out of you let it go.
Now... clunky driveline. I've never gotten used to that. That was present 200 miles after I bought the car. Conveniently not a bunk or dunk or clunk or clanky/clunk/clunk until I was firmly its owner.
__________________
Instagram | My Build
Suspension: Steeda | Aero: Verus Engineering, Kognition Design | Engine/Power: VMP, Solo Performance, ATI
Driveline: Steeda, MGW, Shaftmasters | Wheels/Tires: RAYS, Continental, Nitto
Brakes: GLOC, Ravenol, JLT | Fluids: Liqui Moly, BG, Pennzoil | Affiliation: JZilla Track Days
wildcatgoal is offline   Reply With Quote
Old 10-17-2017, 04:49 PM   #15
Seatown Stang
HereWeGo
I never really noticed it before because I had the MBRP race catback that droned and it drowned out the noise. I just installed the AWE Switchpath, which doesnt drone, and I can hear the gears whine like a mofo at about 70mph
__________________
Users thanking this:
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Clunking in rear with diff bushings. driveshaft/differential? Tugger50H Transmission & Drivetrain 19 07-15-2017 12:46 AM
Differential to Subframe Bushings Nerass Suspension, Brakes & Chassis 6 04-03-2017 01:36 PM
Rear gear noise after bmr cradle lock out and steeda black differential bushings inst doodguy Suspension, Brakes & Chassis 24 10-17-2016 01:53 PM
BMR Solid Diff Bushings and Solid IRS Bushings Install (BK050 and BK048) mtb5020 DIY 11 09-18-2016 02:59 PM
Steeds its support bushings and diff bushings red Viperbluecobra Suspension, Brakes & Chassis 125 01-20-2016 04:31 PM
Powered by vBulletin® Version 3.8.8
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
User Alert System provided by Advanced User Tagging v3.2.4 (Lite) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd. Runs best on HiVelocity Hosting.Navbar with Avatar by Motorradforum
Garage vBulletin Plugins by Drive Thru Online, Inc.
