Can anyone confirm this working? I have a GT Premium Cali Package and has the memory package of seats and mirrors.Found this on a ford fusion forum... It says that it may only work with memory seats/mirror function but Ive seen on another forum to leave C as it is if you don't have it (FC)
REVERSE DIP AND AUTOFOLD SIDE MIRRORS
- Requires Motorized Mirrors to be installed.
IPC
720-02-01: xxxx Fxxx xx
DDM and PDM
740/1-03-01: F800 xx
740/1-12-01: FCxx
740/1-13-01: FCxx
Go into Mirror Settings under Vehicle in IPC to turn both these features on after changing code.
To Use Reverse Side Mirror Dip:
Before shifting into reverse, select the mirror you want by pressing the left or right mirror control button. Then shift to reverse, it should dip.
http://www.mustang6g.com/forums/showthread.php?t=67564So my car has 325/30/19s on the back and my speedometer is 3-4 mph too fast now. what code do I have to change and what do I change it to to correct this. Thanks!
Best bet is to find the as-built for a base auto.Anyone know what to change for the side traffic mirrors? I did an auto swap and used a premium pack as built but I have a base pp and I'm getting an error message for the side mirrors.
If I use a base auto then my performance pack center gauges won't work, and since there is not a performance pack auto base, I used the 50th anniversary that was the closest.Best bet is to find the as-built for a base auto.
