***Urgent*** Check Clutch Line At Brake Master Cylinder
Bill88stang
2016 deep impact blue premium gt 6 speed manual
Has anyone zip tied it to keep secure?
Jmart
South Bay Area
2017 GT PP Premium, Lightning Blue
Just like most in this thread, I can confirm mine was loose. 2017 here with 2400 miles. Looked just like the OP and I felt it seat over the barb with only light pressure.
Draklia
Dry Land
2017 GT
Is this really a problem or just a visual problem. Has there actually been any type of failure. Just wondering if 10 years from now if it wouldn't have mattered if the hose was pushed further or not.
GT Pony
Pacific NW
If the rubber seal inside the end of the tube isn't all the way over the flared end of the nipple, I'd think there's a possibility the tube could eventually work itself off the nipple. Best to have it seated 100% on to the nipple.
Asharus
Boca Raton, FL
Angelo
2018 Challenger Scat Pack
Mine was prob like that for the past 3 years and 30k miles
brandonsmash
SMASH!
Phoenix, AZ, USA
2015 GT - PP
Maybe it's just in my head, but since pressing the fitting back onto the nipple and adding a cable tie to the end to secure it my 2-3 shifts are noticeably smoother and lack the gear "nibble" that I'd felt previously.
So, hey, that's nice!
Clink
'14 Focus
I checked mine today, it's in the middle and doesn't want to go any further up after a girly push so leaving as is.
IvanCRF
El Paso, Texas
5.On'ry
I zip tied mine today because it was at the end of the nipple. The zip tie grabs the rubbery end and the whole line doesn't seem to want to come off anymore.
VinnAY
Kansas City
18 Camaro 1SS/1LE
Placebo
Brostang
Hampton Roads
17 GT-350 Oxford & LB
Mine took just a little more pressure than what I would consider a light push. Some fluid wept from the end when I first tried, but I gave it a little extra and felt a very satisfying snap as it engaged over the barb.
scrubber3
Hopper, is that you?
Sandhills NC
2017 GTPP Shadow Black. 2001 Jeep XJ 4x4
You sure that wasn't the nipple breaking?
NightmareMoon
2016 Mustang GT PP
Mine was at about 8mm and a bit angled, I was only able to push it to about a 5mm gap, since that line is so short. No wetness or signs of leaking though before I toyed with it.
ya you'll get a bit of fluid come through if you push it back on, as you're effectively shortening the line and the pressure has to go somewhere.
Asharus
Boca Raton, FL
Angelo
coulda prob opened the cap before pushing it in to prevent weeping then.
