50 Roll
Specs, Mods, Photos
YEAR
2017
MAKE
Ford
MODEL/TRIM
Mustang GT
COLOR
Magnetic Gray
ENGINE
Aluminator 5.0
TRANSMISSION
MT-82
PACKAGES
Performance Package
MODS - POWERTRAIN / DRIVETRAIN
-Aluminator Long Block N/A 11:0:1 Compression
-ATI Damper
-Comp Cam Stage 2 Blower Cam
-GT350 Intake manifold with adapter to stock GT throttle body
-MMR IMRC Delete
-MMR Oil pump/crank gear
-MMR Billet Chain Guide Kit Fixed
-MMR Billet Secondary Chain Tensioner Bracket
-MMR Billet Secondary Upper Chain Guide
-MMR Secondary and Primary Chain Tensioners
-Procharger Stage II Kit F1A-94 Head Unit (4.24” pulley 20psi)
-Fore Innovations Fuel System Level 4 Dual Pump 1200+hp
-Injector Dynamics ID1300X
-Kooks Long Tube Off-Road Header True 3” to Corsa X-pipe
-Corsa Sport Cat Back
-UPR Oil Catch Can
-UPR Crankcase Breather
-DSS One Piece Aluminum
Driveshaft
-McLeod Twin disc Clutch
-McLeod aluminum lightweight flywheel
MODS - SOFTWARE / TUNE / PROGRAMMER
Rob Shoemaker
MODS - WHEELS / TIRES / BRAKES
-Weld RTS S77 17x5 Front
-Mickey Thompson Sportsman Front Runner Tires 28/6R/17
-Weld RTS S77 17x10 Rear
-Mickey Thompson ET Street S/S Radial 305/45/17
-Baer Drag Brakes front and rear
MODS - SUSPENSION / CHASSIS
Front Suspension
-Koni Yellow Adjustable Shocks
-BMR Drag Springs
-BMR Caster Plate
Rear Suspension
-Viking Double Adjustable Shocks
-Steeda Shock Mount
-Steeda IRS Alignment
-BMR Drag Springs
-BMR Aluminum Diff Insert
-BMR Cradle Lockout
-BMR Delrin Lower Control Arm
-BMR Delrin Vertical Links
-Whiteline Adjustable Sway Bar
MODS - INTERIOR
-Fathouse Fab Driver Side Seat Bracket
-Kirkey Race Seat
-GT350r Rear Seat Delete
-Brey Krause Harness Bar
MODS - IN-CAR ELECTRONICS
Hp Tuner N Gauge
Item information
Added by
chrisxrobinson
Views
2,090
Comments
Last update
More in Mustang GT
Share this item
