If you are feeling adventurous and not afraid of cutting into your 2015 Mustang’s factory orange peel, you may want to check out this buffing method turned-modification that has led to a fantastic result for M6G member NotBlake.
By using a denim buffing pad to cut into the exterior paint along with Meguiars M105 ultra-cut compound polish, this extreme buffing method cut down the peaks of the clear coat to result in clarity and sheen that you are unlikely to see elsewhere. This Magnetic 2015 Mustang GT was then finished off with a synthetic sealant to compensate for the reduction in protective coat.
Read more about this process in the FORUMS.
