M6G Giveaway: S550 Convertible Full Length Jacking Rails
by • December 5, 2016 • NewsComments Off on M6G Giveaway: S550 Convertible Full Length Jacking Rails4018
Our friends at Hotpart.com have recently released full length, low profile jacking rails designed specifically for the S550 Mustang Convertible and we’ve teamed up with them for another M6G Giveaway Contest!
These rails are CNC laser cut and tig welded, utilizing machined inserts that get tig welded into the rail to provided maximum strength and rigidity.
The design fully protects the rocker panels and factory jacking points from damage when jacking up the sides of your S550 Mustang in your driveway, at the track, when performing oil changes or during “off roading” by protecting the factory pinch welds and rocker panels from damage, folding or collapsing.
The J&M Products jacking rails are unique in that they feature recessed mounting hardware with no bolts protruding from the underside of your S550. They can be installed very quickly by removing the factory hardware under the rocker panel at the front and rear of your convertible Mustang and using the included grade 12.9 hardware to bolt the new jacking rails to the underside of the car — a very quick and simple installation to provide one convenient spot along the side of your vehicle to jack up your S550 Mustang convertible.
See the full J&M Products S550 Mustang Convertible Full Length, Low Profile Jacking Rails 25500 details and giveaway contest in the forums.
