M6G Giveaway: J&M Products 2015-2017 Mustang IRS Rear Vertical Links
We’ve teamed up again with our friends at J&M Products for another Mustang6G Giveaway Contest!
J&M Products has designed and manufactured all-new Mustang Billet Aluminum Vertical Links for the 2015-2017 Mustang GT, EcoBoost, and V6, constructed from aircraft grade 6061-T6511 aluminum.
These all new Vertical Links feature super high-strength spherical bearings and incorporate CNC-machined billet tapered and reducer bushings for the perfect bolt-in fit. The use of these specially designed spherical bearings provide benefits over standard bushings, eliminating deflection and providing consistency in the rear suspension geometry under the most demanding conditions. These new billet aluminum links will eliminate deflection under the most severe of loads reducing wheel hop and increasing traction.
Unique to these vertical links are spherical bearings that are special-built to J&M Products’ specifications. Whereas traditionally the bushing is made from delrin or a polyurethane material, J&M Products’ spherical bearings are made from 52100 heat treated steel/hard chrome plated ball. The bearing race is heat treated 4340 chrome moly with a load rating of 78,000 psi when most others are rated at 48,000 psi.
Further, the bearing liner is not the typical PTFE liner but rather made from a thin sintered bronze wire net impregnated with PTFE powder, giving it great load capacity and longer wear. This is the same liner material that is used in modern ball joints for a maintenance-free long life.
Check out the Giveaway Contest and the full product details of the J&M Products 2015-2017 Mustang IRS Rear Vertical Links Wtih Spherical Bearings in our forums.
