We’ve teamed up again with our friends at J&M Products for another Mustang6G Giveaway Contest!
J&M Products/Hotpart.com has introduced its new Mustang IRS Rear Toe Adjustment Links (Part # 25410), providing a direct bolt-on upgrade replacement for all 2015-2017 Mustangs, including the V6, EcoBoost, GT and Shelby GT350 models.
The stock toe adjustment links have a tendency to flex under heavy cornering giving you inconsistent rear toe alignment and irregular, wonky handling characteristics. J&M’s Rear Toe Adjustment Links are designed to address this issue in order to allow you to precisely set toe alignment for your specific driving attitude, improving driving confidence whether on the street or the track.
Manufactured from heavy-duty DOM steel tubing 2015-2017 Mustang IRS Rear Toe Adjustment Links are pulse-welded high strength tube adapters with a heavy-duty chrome moly center adjusters make on-car adjustments simple and easy. The open end that attaches to the rear hub is laser cut and CNC formed 3/16-inch steel plate. The subframe end features heat-treated, chrome-moly, self-lubricating bearing. Bearing liner is attached with a thin sintered bronze wire net impregnated bearing race is heat treated 4340 chrome moly steel with PTFE powder, same as modern ball joints. The rod end bodies are constructed of heat treated chrome moly alloy steel. The rod end spacers are custom designed and CNC machined from 6061-T6 billet aluminum.
Check out the Giveaway Contest and the full product details of the J&M Products 2015-17 Mustang IRS Adjustable Rear Toe Adjustment Links in our forums.
