djone101
We can now offer XForce exhausts to UK customers - we've installed a few on customers cars over recent months. XForce produce very high quality systems in Australia so everything is engineered to work on RHD cars.
There are lots of exhaust suppliers out there but the XForce system has a few unique qualities we haven't seen elsewhere. The exhaust is designed in a very modular fashion meaning you can fit a 3" cat back with their Varex variable valve controlled mufflers with either twin or quad outlets, controlled by a key fob switch or by a more controllable smart box option. You can then add full headers to the car with cats for the full front to back system.
We've fitted a number of their headers and whilst the install is not a quick job the system fits very well. The system is 1 7/8" and uses high flow metallic catalysts.
Uniquely the exhaust is all bolted flanges rather than slip joints which means the parts have to fit right due to reduced tolerance in the joints.
As the rear mufflers have single outlets you can fit the supplied 100mm tips with the standard rear valance or you can opt for the quad outlets which work with the Roush rear valance or with the various other rear valances out there like the carbon fibre ones from Anderson Composites.
If you take a look on the XForce web site there are plenty of sound clips. The difference between open and closed is amazing. I would say that when closed the system is as quiet if not quieter than stock. While open is at least as loud as Roush axle backs. The best of both worlds. The key fob option is a simple open/closed system while the smart box means you can use the app to control the system with amazing amount of flexibility. More details are on the web site.
Parts prices are as follows:
Headers £1599 inc VAT
Cat back with Varex mufflers (key fob controlled) and twin tail pipes £2189
Quad tips to fit cat back £289
Smartbox bluetooth variable exhaust controller £729
Pictures below of a system fitted last week with the Varex key fob controlled cat back and quad tips with Roush valance. I'll post other pictures of the headers later.
freeimagehost
freeimagehost
