I'd be on the e85 only regimen with this. It just really narrows your tuning window with that amount of static compression.Boost+ 12-1 compression+pump gas=Boom and smoke.
Prolly a 6060 too.. Jamal stated that the trans was lightened as much as possible to allow it to meet the needs of the power train. This engine naturally aspirated isnt much in the torque department. With a turbo I'd expect that to jump significantly.I agree 110%. No loads on the crank, no additional vibrations or harmonics, no hood clearance issues. Better figure in a new clutch during TT or blower install. 1/2 shafts would be a good idea also.
Yeah definitely a trans.Prolly a 6060 too.. Jamal stated that the trans was lightened as much as possible to allow it to meet the needs of the power train. This engine naturally aspirated isnt much in the torque department. With a turbo I'd expect that to jump significantly.
Holy Shat! that owner has some balls! are those the 55mm you have there in the picture? looks like its a tight fit, wondering if one can go 67'sHellion is proud to announce that we have built a twin turbo system for the GT350 and it will be available soon!
This system is bolt on, and is very similar in design to our on the shelf 2015-16 GT kit.
The system will come standard with twin 55mm Precision turbos, with up to twin 64mm units as an option.
More details to follow soon. The installation of this kit will soon be on the famed television show Engine Power!
Remember, one of the biggest advantages of a turbo setup----no pulling on the crank---- Especially the flat plane crank!
Team Hellion
Yes. The base kit comes with quick spool 55mm units, and we can go all the way up to a 67mmHoly Shat! that owner has some balls! are those the 55mm you have there in the picture? looks like its a tight fit, wondering if one can go 67's
The entire install will be on the television show engine power. We will release more info here very soonBoinnnnnnggggggggggggggg................ Video?? More pics?? Dyno numbers?? Cost???
Release more now!!!!! Was literally thinking when is hellion coming...The entire install will be on the television show engine power. We will release more info here very soon
Not a fan of FI, but looking forward to see the show!The entire install will be on the television show engine power. We will release more info here very soon
Depends on how much boost they are pushing, but I highly doubt they are going to build a kit just to blow someone's engine.Boost+ 12-1 compression+pump gas=Boom and smoke.
