They fit i have done this setup before, you need a 5 mm spacer upfront for caliper clearance.Trying to plan out what wheels I want. Planning on lowering the car on eibach pro kit springs. Wanting to run 20x11 et50 out back and 20x10 et40 up front. Will these fit? Don't want to have to do anything with my fenders at all.
Thanks man. What size tires would you recommend? Don't want to deal with any rubbing. And if it not too much trouble if you could pm me a price. Not buying right now but planning on it in the next couple months just planning out what I want to do and how much it will be. Thanks!They fit i have done this setup before, you need a 5 mm spacer upfront for caliper clearance.
Let me know if you need inventory checks and or pricing im a distributor for TSW.
I say the 10/11 personally for the deep concave and wide width for the car.Thanks man. What size tires would you recommend? Don't want to deal with any rubbing. And if it not too much trouble if you could pm me a price. Not buying right now but planning on it in the next couple months just planning out what I want to do and how much it will be. Thanks!
What specs did you go with?Does anyone have a pic of the inside mounting surface of the Bathurst? I got the wheels on order and I was thinking of putting a 15mm spacer up front so the wheel sits more flush with the fender. But my concern would be that I need to make sure that when I install the hubcentric spacer the original stud will stick out past the mounting surface and that the Bathurst wheel would be able to mounted
You can do hubcentric or generic all depends how much you want to spend to be honest.Ok. Thank you for answering my question . Any 5mm spacers you recommend?
