Will they fit: 19 x 10.5 +45
mtpavelka
Dallas, Tx
2015 Ecoboost Mustang
I'm looking at a 19 x 10.5 +45 wheel for 305/35/19 NT05R.
Will the 19 x 10.5 +45 wheel fit right?
Schu
Las Vegas, NV
S550GTPP
why would they not fit up front? you'd need a spacer, but they would both fit... and stick out. :p
DWC_SmOziLLa
Pennsyltucky
Black '05 Audi A4 3.0 V6 Quattro UltraSport 6 Spd.
There is multiple reasons why they wouldn't work up front. Most 10.5 with a +45et have a deep concave, to achieve this, most of the time the hub portion of the wheel is noticeably thinner then most wheels. In most cases, one of two things, or both, will happen. The center caps will not fit because of the front wheel bearing dust cap, or the spokes of the wheels come in contact with the brake caliper. Both of these problems can be typically solved with a 3-5mm spacers. But then you have already introduced a new problem to a already problematic wheel, with a +45et on a 10.5 wheel up front you will already be poking out past the fender about 1-5mm more then most guys running a aggressive fitment up front with a 9.5" or 10" wheel. If you put a spacer on there you just compound the issue.
Good Luck!
