Will a 325 width rear fit on GT500 CF Rims?
Snake Oiler
'93 Rx-7, '05 Kleemann SLK55, '20 HPE850 GT350
I'm looking to replace my OEM 31 lbs GT350 rims with either forged magnesium or CF and was curious if the GT500 CF stock rears accomodate a 325 width. Anyone know? Thanks much.
ZeroTX
ZERO
2022 Mustang GT
Forgive my ignorance, but what's the wheel size and width?
DopamineQuest
Ohio
www.instagram.com
2021 GT500 Carbonized Gray
They'll fit easy on the 11.5 inch wheel, not sure about clearance for rubbing and stuff
ZeroTX
ZERO
2022 Mustang GT
For sure will fit on an 11.5 wide wheel, but as some mentioned, not sure about the clearance. I have a GT, so I don't think they have the same fitment.
Snake Oiler
Snake Oiler
This is good info but your point wrt rubbing is also key. Perhaps a GT500 (CF rim optioned) owner can confirm if the 325s have any chassis rubbing issues (I could be wrong, but I don't think there is any GT500 to GT350 rear chassis fitment differences so if a GT500 20x11.5 wearing 325s "fits", they should also fit my GT350)?
Again, thanks to all for the input thus far - appreciated.
wingnutt
@FL410
michael
350R avalanche grey
Goodyear Eagle F1 325/30/19 on my 350R (CF rims) no rubbing, but a tad more poke than some would like 😬
WItoTX
Houston
Kyle
'17 GT350
Look up the actual dimensions on the tires you are looking to buy. a 325 is not a uniform size across the manufacturers. That said, I would imagine just about any 325 would "fit" on an 11.5" wheel.
That should help narrow down how wide of rubber you want. As to getting a wider tire, you really aren't gaining anything, and arguably harming the handling characteristics of the car.
Snake Oiler
Snake Oiler
Thanks for top down pic. That is entirely acceptable IMHO.....does not poke out too much. Exactly what I was looking for per my question. Cool......325s will help a bit with acceleration traction.
agmattocks
Unstabled Mate
Snellville, ga
Anthony
UMMC 026 - 2021 MACH 1 w/ handling package
325's will fit fine. I went from 315 to 325 on mine. the 315 looked a tad stretched while the 325 make the sidewall perfectly vertical IMHO.
Snake Oiler
Snake Oiler
Yup, agree in the non width uniformity amongst tires. However, for primarily street use, the additional ~1.6" net rubber contact patch will help under hard acceleration.....the car has 852 rwhp. I'll also be dropping ~115 lbs in rotational mass with the replacement rims and carbon brakes as part of its 'diet" so the car's overall performance should improve a bit. Have a good W/E Kyle - appreciated your feedback.
-Matt
2019GT
New York
19' GT
2019 Mustang GT
Also keep in mind tire diameter as well. I was running into traction problems on my whipple set up, mostly due to not wanting to run an R Compound. I was on 325/30/19, and opted for 315/35/20, which is a 2" difference in height. I can almost hook 2nd gear on the taller tires where I could only dream of that with the 325s lol.
Kenbike
Ohio
2015 CO Mustang GT convertible loaded
Taller tire hook much better and reduce the gear ratio some.
You can determine the size difference between the shorter and taller tire to see what percentage they change.
ZeroTX
ZERO
2022 Mustang GT
Taller tire negatively affects gear ratio for power and acceleration. Also taller looks dumb unless you're building a drag car.
Cgouzoulis
chris
None
I disagree. I think they look great and you dont need a drag car to have a need for a taller, stickier tire.
