bullittman
Did some searches but did not get an answer, wondering if the mtg holes are the same. Thxs
It’ll be fine . The tech spoiler is held together with double sided tape so you’ll have to use something like fishing line to remove it. Once it’s off clean off the adhesive with something like Goo Gone and you can put on the 17/18 spoiler . I have a 2017 gt 350, but I used to have the 2016 tech and I removed it and put a R wing on it and had to cover up the holes because the R wing doesn’t mount in the middle , it mounts in the sides .Did some searches but did not get an answer, wondering if the mtg holes are the same. Thxs
https://www.ebay.com/itm/372923103945It’ll be fine . The tech spoiler is held together with double sided tape so you’ll have to use something like fishing line to remove it. Once it’s off clean off the adhesive with something like Goo Gone and you can put on the 17/18 spoiler . I have a 2017 gt 350, but I used to have the 2016 tech and I removed it and put a R wing on it and had to cover up the holes because the R wing doesn’t mount in the middle , it mounts in the sides .
