Who will swap for the new 7.3 V8!
Discussion in 'Mustang S550 General Forums' started by Fatguy, Mar 9, 2019.
  1. Big Boss
    Big Boss Well-Known Member
    Vehicle(s):
    Mazda6
    Oct 28, 2015
    Outer Heaven
    682
    203
    0   0   0
    To me I always considered bolt ons stuff you could do fairly quick, with basic hand tools and little to no experience turning wrenches.
  2. Hack
    Hack Well-Known Member
    Vehicle(s):
    Mustang, Fiesta
    Nov 26, 2014
    Minneapolis
    9,480
    4,737
    0   0   0
    To me then it isn't "full". I realize it's off topic to the 7.3 swap discussion, but FBO drives me absolutely bonkers. "Full" absolutely implies everything. If you only did nothing burger changes like a CAI, just say you did a CAI rather than using a vague phrase that sounds as though you might have made a change that impacts power significantly such as heads, cams, stroker kit, turbo, etc.
    Big Boss likes this.
  3. Big Boss
    Vehicle(s):
    Mazda6
    Oct 28, 2015
    Outer Heaven
    682
    203
    0   0   0
    I agree, what I was commenting on was the debate over what some people consider bolt ons.
    Hack likes this.
  4. millhouse
    millhouse Well-Known Member
    Vehicle(s):
    2016 Ruby Red GT PP
    Jun 27, 2016
    Simpsonville SC
    2,613
    1,191
    0   0   0
    A supercharger is pretty easy to bolt on.
    Hack likes this.
  5. tokuzumi
    tokuzumi Well-Known Member
    Vehicle(s):
    2004 Escalade ESV
    Apr 3, 2019
    Atlanta
    344
    160
    0   0   0
    FBO to me means leaving the long block, transmission, and differential intact.
  6. bootlegger
    bootlegger Enginerd
    First Name:
    James
    Vehicle(s):
    Ex 2008 Mustang GT Owner
    Jul 12, 2017
    Mount Pleasant, SC
    1,750
    561
    0   0   0
    A tuner/programmer is a required part for modification. Even without a tune, the units are $400.
  7. millhouse
    Vehicle(s):
    2016 Ruby Red GT PP
    Jun 27, 2016
    Simpsonville SC
    2,613
    1,191
    0   0   0
    I've always this considered part of the tune, and this would be required for any vehicle or engine.
    But again, I would go with a stand alone EFI managment for the 7.3L for any type of retrofitting.
  8. bootlegger
    bootlegger Enginerd
    First Name:
    James
    Vehicle(s):
    Jul 12, 2017
    Mount Pleasant, SC
    1,750
    561
    0   0   0
    Then you are talking more than $1000 for the equipment alone. Programmers are only required when modding.
  9. millhouse
    Vehicle(s):
    2016 Ruby Red GT PP
    Jun 27, 2016
    Simpsonville SC
    2,613
    1,191
    0   0   0
    Stand alone systems can be had for ~ $1000 or less...all wiring included. For any type of retrofitting, this is the way to go. Even LS1 stand alones cost more or less the same. All of these systems self learn...and there is no need for any dyno time or mail order tune costs.
    This doesn't change engine costs though. And again, I'm not talking about taking out a coyote and swapping in a 7.3L.
  10. bootlegger
    bootlegger Enginerd
    First Name:
    James
    Vehicle(s):
    Jul 12, 2017
    Mount Pleasant, SC
    1,750
    561
    0   0   0
    Swapping in a 7.3 for any application and adding bolt-on mods will require a programmer, if you don't go the standalone route.
    In regards to the standalone (like the Holley unit), their self-learning leaves a lot to be desired. My friend has the Holley system on the twin turbo LSX he installed in his boat. It has never really run quite right, and is going to have to be tuned. If you want to really get the most out of those, you will need to hit a dyno. I would stick with a SCT or n-gauge if I wasn't fairly experienced in tuning.
  11. millhouse
    Vehicle(s):
    2016 Ruby Red GT PP
    Jun 27, 2016
    Simpsonville SC
    2,613
    1,191
    0   0   0
    I have used self learning Fitech. It worked amazingly well. Stupid easy to set up. Stupid easy to learn. My 427 with a fairly lopey cam had no issues idling.
    And no, you don't need to hit a dyno. WOT self learning can be done on the street or at the track. Tunes come in conservative. You input your engine size, cam size, N/A or FI and it throws in conservative tables....enough to get the engine started and running.
    I've used these. I know others that have used these. They work very....very....very well. Holley's are setup very much the same way....almost scary close to the Fitech.
    Those that have problems, they are nearly 100% of the time attributed to poor grounds, poor crank/cam pickup signals or vacuum leaks.
  12. NotagainV2
    NotagainV2 Well-Known Member
    First Name:
    Tyler
    Vehicle(s):
    19 F150 19 Explorer 04 Thunderbird
    Dec 14, 2019
    Washington DC
    89
    Everyone in here be like that expense doesnt count....... .Neither does that expense..... itll be cheap in 5 years..... LMFAO!!
  13. tokuzumi
    Vehicle(s):
    2004 Escalade ESV
    Apr 3, 2019
    Atlanta
    344
    160
    0   0   0
    It will be cheap(er) in 5 years.
  14. Dominant1
    Dominant1 Well-Known Member
    First Name:
    Dr Frankenstang
    Vehicle(s):
    2016 gt/cs auto 3:55 gears
    Jun 17, 2016
    2,645
    583
    0   0   0
  15. shogun32
    shogun32 Well-Known Member
    First Name:
    Vehicle(s):
    2019 GT+PP, EB+PP, SS+1LE, GTI Rabbit
    Feb 8, 2019
    Northern VA
    2,544
    985
    Garage Profiles:
    there are already a good handful of shops that build 427 from the Coyote platform (boss crank, blocks, heads)
Loading...
Share This Page
