bootlegger
Enginerd
- Jul 12, 2017
- Mount Pleasant, SC
- James
- Ex 2008 Mustang GT Owner
He has checked every part of the system. He has been talking to a local boat racing shop, and they told him the systems aren't perfectly plug and play. They need some adjustments to really pull right, especially on custom twin turbo jet applications. Grounding isn't that hard on a boat. Your battery is right next to the engine.I know first hand someone with a turbo LS that has had no issues with theirs. They work with old N/A engines. They work with new N/A engines. It doesn't matter what engine you are using. These systems all work the same way....old and new.
If his boat isn't running properly, it's his fault. Check the wires. Check the vacuum lines. Check and recheck the grounds. Grounds are the number one cause of issues in a car. I can only imagine in a boat.
Since when do you need dyno tuning with a Lund or PBD tune? You take it to the track, datalog, and the tune is adjusted based on the logs. If you add a part, drive it some, make some pulls, datalog, then the tune is adjusted. I would be doing the same thing if I tuned myself or used a standalone, because I have worked in engine development and don't trust an ECU to do everything for me (factory or aftermarket).As for maximizing power, that can be done for much cheaper at your local dragstrip. You only adjust one variable...timing, and the computer maximizes your fuel ratio. A few runs down the dragstrip is a hell of a lot cheaper than dyno time. I've done both, so I know first hand. Your friend with your boat isn't so lucky, but he has some unusual circumstances not relevant to this conversation.
What is "hot rodding"? No, I don't drag race, if that's what you mean. Never heard someone call that "hot rodding". I prefer to turn the wheel, personally. When I lived in IL, I would run AutoX during the summers. Now I just try to look for track events that aren't expensive. If real hot rodding means just bolting up a special engine to be original, then I guess you can count me out.The reason you would never buy a stand alone is because you don't do any real hot rodding.
You literally said the standalone systems are plug and play, and require no tuning. What is easier (or lazier) than hooking up a system and letting it do all the work. And no, I didn't pay someone to do the work for me. I datalog regularly and review every log. I don't just trust the adjustments made by PBD. I don't have the software to adjust my tunes, nor do I have the experience on the Coyote dual fuel system. The standalone system is either plug and play, or it isn't. Sounds like you want the ECU to do all the work for you. Personally, I enjoy collecting and reviewing data from my system.It's easier for you to have someone email you a tune based on your combination. You paid someone else to do the work for you. There is nothing wrong with that. That's what the coyote allows for.
If you are pulling an engine out of a junk yard, why wouldn't you take the ECU as well. There is no reason it would cost $2000+. It will likely be included in the cost of the complete engine. The rest of the nonsense you are spouting sounds like you have no experience wiring with PBD or Lund. Have you even modified your S550? For $600, I bought my SCT unit and 2 base PBD tunes for stock intake and 2 for a JLT intake. 2 were for 93oct and the other 2 were for E85. This included 3 months of support, so I was able to datalog with each map and have the map fine tuned for best performance.It's also a $2k+ add on for a swap and will require you to spend your money on a tune not just for the install, but anytime you make any change. You wan't to try a different intake? Call up your tuner. You wan't to try different headers? Call your tuner. You wan't to try E85? Call your tuner.
I've got new for you. Most people that do engine swaps don't have the time or money to call a tuner every time they wan't to make a modification.
If I want to add intakes or headers, I just pay $50 for another 3 months of support. It will include base 93oct and E85 maps for the add-on parts, which will run just fine no matter which set of headers you want to try. After all, the ECU on the Coyote learns as well. If you change headers, you can datalog and have the map adjusted for best performance.
This is all a bit silly. Any person with the skill to perform custom engine swaps will likely know enough about tuning to play around with the maps in a standalone. If you don't have that skill, you are going to leave a lot on the table relying on the self-learning ECUs.
