Norm Peterson
corner barstool sitter
Even without knowing a thing about the man, why am I not surprised?The same man that brought us the CobraJet program spearheaded this engine.
Norm
It would be interesting in a Fox body or SN95/New Edge. I was at the track in July to visit with an old friend who was racing and there was 0 LS powered S197 and S550s. Handful of Fox bodies and SN95s with LS power plants but 0 S550.The 7.3 liter motor is better, for a truck. How many of you want to swap your Coyote V-8 for a powerstroke diesel? There are some out there that would do it, because they can! The 7.3 swap would be interesting, however I don't think we will see a mass migration to it at the drag strip.
The bore spacing is 4.53 inches.
This makes it the largest displacement small block Ford has ever offered.
The 7.3 is shorter in length and height.
Also, it's much more narrow than anything mod motor.
Imagine, decent set of shorty headers.
Proper intake......?
445 cid small block.....easy 550 hp without revving it to the moon
Gobs of torque all over the tachometer.
Thank You Brian Wolfe.
When you fail at technical discussions, always reach for the magazine popularity.Hot Rod Magazine has pinned the article about the 7.3 for three days now.
It's been at the top two days longer than the C8 debut.
Retired Ford executive Brian Wolfe.Even without knowing a thing about the man
You mean people didn't work over the weekend?Hot Rod Magazine has pinned the article about the 7.3 for three days now.
I can answer your last ponderance (can't think of an actual word that fits here...). reliability. given the extremely fast and variable cycling needed (33 times per second at 8k rpms, at as low as 1/130th a second cycle speed, to as long as 1/12th cycle speed) and high temp and thermal cycling, and needing 100% functionality for 16 solenoids, the reliability just isn't there. Considering that a single hiccup on a single solenoid could grenade the entire engine, just don't see it being a feasible option.If you're referring to the profile of the cam, it's still fixed. You can adjust the cam phase angle with respect to the crankshaft on the fly, but the intake to exhaust phasing is set. The beauty of separate cams for intake and exhaust is the ability to modify things like valve overlap while the engine is operating.
It also makes one wonder why we're still messing with cams anyway when a solenoid can act directly on the valve.
Stop lying.The 7.3 is shorter in length
Seems to have the issues I described above. This tech is used in diesels on the injectors, which are a less severe service than what would be needed on a gas car. the diesel injector has less cycles/second, and duration is longer. And they still cost an arm and a leg to replace, and go out relatively often, probably the most replaced part of the engine. And the system to operate it is also another major headache and source of frustration (I have to pull the HPO system apart in my truck this month actually..)Been done already.... Next!
