garykarabetian
- Apr 28, 2016
- california
- 2015 mustang gt
Email me [email protected] if interested $450.00 final price located in California Los Angeles. Brand new in box :cheers:
Improves Handling Performance
Eliminates Body Roll
35mm (1-3/8") Diameter Front Sway Bar
24mm (1") Diameter Rear Sway Bar
Both are Three Position Adjustable
Solid Spring Steel Construction
Fits 2015-2017 Mustangs
DESCRIPTION
Improves Handling. Improve the handling performance of your S550 Mustang by replacing those skinny weak front and rear factory sway bars with a Whiteline Performance Heavy Duty Adjustable Sway Bar Kit for superior handling, flatter cornering and better grip.
Three Position Adjustable. These Whiteline Performance Heavy Duty Sway Bars feature three (3) adjustment positions for fine tuning the handling balance of your Pony to suite your driving needs from mild to wild.
Front Stiffness (Compared to OEM) Position: 1 = 175%, 2 = 159%, 3 = 142%
Rear Stiffness (Compared to OEM) Position: 1 = 201%, 2 = 163%, 3 = 134%
Superior Materials. Manufactured from solid spring steel for superior strength, Whiteline Performance Heavy Duty Sway Bars perform as a spring more effectively than hollow/tubular, non-spring steel sway bars. The front bar features a 1-3/8" (35mm) diameter, where the rear bar is 1" (24mm) diameter.
Application. This Whiteline Performance Heavy Duty Adjustable Sway Bar Kit is designed to fit all 2015-2017 Mustangs including the V6, EcoBoost and GT models.
WHAT'S IN THE BOX
(1) Front Sway bar
(2) Adjustable end links
(2) Lateral locks
(4) Bushings
(4) Washers
(1) Rear Sway bar
(2) Bushings
(2) Mounting Brackets
Installation hardware
DESCRIPTION
WHAT'S IN THE BOX
(1) Front Sway bar
(2) Lateral locks
(4) Bushings
(4) Washers
(1) Rear Sway bar
(2) Bushings
