Slopoke
- Nov 5, 2019
- Left Coast.
- Ed
- 2019 Mustang GT PP1 10R80
I'm just curious if anyone with a Whipple supercharger, with only a oil fill plug has had to do a oil change yet. I just did an oil level check and since in my case, I had to use a mirror to see the plug. I just filled a syringe that had a clear tube at the end and squirted oil into the fill hole and let it dribble out onto the rags I stuffed below the fill port. Then re-installed the fill plug when it quit flowing out.
It doesn't seem like you can stick a tube to the bottom and suck the oil out, by looking through the fill port. With that, it seems like you have to pull the blower and stand it on end to get the oil out. Thank goodness, IIRC Whipple recommends the change at 100K.
