Stock engine turbo coyote mustangs have been 7sI am the second owner of my car . It has the whipple tune from the original owner. Since its just a basic flash it must be a little on the rich side and not pushing it with timing and has other safe modes. I saw in the directions for the flare tool it will also richen the A/F 1 point I think if the cats show they are getting hot. I am not a expert on these new cars but Drag raced for decades spraying 2 stages of nitrous and been 7.53@185 with my old big tire pro street Camaro. Leaning it down and adding timing and you go faster until you pinch a ring land pretty much. Im sure there must be a little room to get closer to the edge without hurting it and thats what a good custom tune should do.
That is great. technology has advanced big time. I was only mentioning it because I did race and tune my stuff. Though these cars are different it still comes down to adding as much timing you can get away with and leaning it down without going to far. That was back in 2009 with a 598 BBC with single carb .Stock engine turbo coyote mustangs have been 7s
My point was that there is still a lot more power that can be had. These cars are actually pretty easy to tune. If you understand the basics you can tune these cars. The better you understand the better you can tune. If you have tuned before you could do it on these. You’re just dialing in the same parametersThat is great. technology has advanced big time. I was only mentioning it because I did race and tune my stuff. Though these cars are different it still comes down to adding as much timing you can get away with and leaning it down without going to far. That was back in 2009 with a 598 BBC with single carb .
With a stock Whipple tune, someone mentioned potentially running a tad rich for ‘safety’... does that yield extra wear and dirtying of the cats long term? And if so... what’s considered ‘long term’?
I’m in California and don’t have to worry about smog tests. Not many people know that some parts of California don’t do smog inspectionThe general consensus is that the stock cats will most likely fail under boosted conditions. That's why I removed mine and will reinstall at smog inspection time. This is not just a Whipple thing. There are Roush boosted cars that have had their cats fail.
that’s comforting. Only 8500 or so on mine. A out 6000 with the Whipple.35K on my setup with the whipple tune and the cats are fine so far.
