Wickedluis
Yes,it's the relay.My dual fans run 24/7. Loud Bi***. Make sure your pump is atleast working and pumping the coolant through the whipple system. Id bet relay as mentioned above.
Sounds like the relay is not up to the task, maybe there is a heavier duty cycle capable one that you can use instead?I just checked the relay, it's burnt at pin 87.
Thank you
I emailed whipple back since it's under warranty but I am going to see if I can find one .Sounds like the relay is not up to the task, maybe there is a heavier duty cycle capable one that you can use instead?
It's the relay. I took it apart and it's scorched. Going to have to wait for whipple to send me one since I can't find it locally.It could be the fans gave out. Just because it’s new doesn’t mean it’s going to last. Maybe got a set of fans with bad motors and they gave out already. I’m sure that you’re not the only one this has ever happened to.
Awesome easy peasyIt's the relay. I took it apart and it's scorched. Going to have to wait for whipple to send me one since I can't find it locally.
Yes same as mine.I just checked the relay, it's burnt at pin 87.
Thank you
Awsome. ThanksThis is the relay Whipple suggested to me to buy . No issues after installed.
https://www.amazon.com/ONLINE-LED-STORE-Waterproof-Harness/dp/B01N66W2XF/ref=sr_1_12_sspa?crid=2WWU0FC2NWRBV&keywords=bosch+relay+12v+30amp&qid=1584401628&sprefix=bosch+relay+,aps,203&sr=8-12-spons&psc=1&spLa=ZW5jcnlwdGVkUXVhbGlmaWVyPUFMSUlLWFQwNE1LRE4mZW5jcnlwdGVkSWQ9QTAwODU3MjAxTVNOUTVBMEFCRE5PJmVuY3J5cHRlZEFkSWQ9QTAzODg1NDYyMjM5WVpOV0k0NUsmd2lkZ2V0TmFtZT1zcF9tdGYmYWN0aW9uPWNsaWNrUmVkaXJlY3QmZG9Ob3RMb2dDbGljaz10cnVl
No problem glad I could helpAwsome. Thanks
