Whipple dual fan not turning on ,2022 mustang gt stage 2 whipple
Wickedluis
Austin TX
Luis Salmon
2022 Mustang Gt PP1 Stage 2 whipple
So I just noticed the dual fans that came with the stage 2 whipple supercharger kit are not turning on anymore. They used to constantly run when the car was on.
I checked the fuses and everything seems fine. Anyone have any ideas?
KingKona
Virginia
Shlomo
2019 GT
What do you mean "it's not on anymore"???
You gonna provide any better information than that?
What fan(s) are you talking about? Who installed them? When were they installed?
Wickedluis
Austin TX
Luis Salmon
I had a performance shop install a whipple supercharger kit with dual fans for extra cooling. This fans are attached to the front of radiator 2022 mustang gt. They used to run all the time while the car was on but suddenly stopped working.
Cordero1
Kansas
Vic
2021 Mustang
Those fans were so annoying that I almost wanted to get rid of my Whipple.
KingKona
Virginia
Shlomo
2019 GT
1. Fans usually aren't supposed to run all the time.
2. Only the shop can answer your concerns.
Wickedluis
Austin TX
Luis Salmon
They are pretty annoying ..lol I noticed my car sounded different yesterday and I couldn't tell what it was . I figured it out when I was at a drive through, the fans were not on any longer.
Wickedluis
Austin TX
Luis Salmon
These fans run constantly when the car is one . I submitted a trouble ticket to whipple since I am not dealing with that shop any longer . Just wanted to see if anyone here has had this issue
Thanks
KingKona
Virginia
Shlomo
2019 GT
These fans run constantly when the car is one.
You know for a fact they're supposed to run constantly when the car is on? Whipple told you that?
Wickedluis
Austin TX
Luis Salmon
According to Whipple and every one else I have talked to yes, these fans run constantly . Right now its in the 60s in central Texas so its not an issue . I just noticed they stopped working when I was at a drive through and I could not hear all the noise any longer. I checked the fuses and harness so far. I am waiting on whipple to respond and I am also under warranty , just wanted to see if anyone on here has had this issue and a fix before I have to take it to a shop.
KingKona
Virginia
Shlomo
2019 GT
They run constantly if they're wired that way.
It could be they were wired to come on when your coolant is at/above a certain temperature, like the stock fan does.
Cordero1
Kansas
Vic
2021 Mustang
Yeah they do run non stop from the second you turn the key on. They are annoyingly loud. I also thought they only worked at a set temp, but emailed Whipple & was told they run at all times
Wickedluis
Austin TX
Luis Salmon
They are usually on when temp is cold first thing in the morning. The temp got up to 221 today and nothing . The stock fans are still working.
Lubner
Long Island NY
Joseph
Mustang
The Whipple fans run constant. I had a relay fail on my 2016GT with Whipple fans that caused the fans to stop. I did not like the fans always running that's why I just went with HD exchanger on my 22 GT with Whipple.
sabtaj1
Bettendorf, IA
Jason
2019 PP1 Mustang GT, 1965 Fairlane 500 wagon
My dual fans run 24/7. Loud Bi***. Make sure your pump is atleast working and pumping the coolant through the whipple system. Id bet relay as mentioned above.
Wickedluis
Austin TX
Luis Salmon
I just checked the relay, it's burnt at pin 87.
Thank you
