tracktardicus
Anyone have any info on when the OEM non-drilled rotors will be available?
KR3Z 1125 CWhen I spoke with WBLAN last month, they didn't have a timeline. Hopefully in the next month or two, tho. Hoping I can stretch it out and get a pair.
Ballin'. Think that date is fairly legit? Can't wait to get my hands on a setKR3Z 1125 C
KR3Z 1125 D
Both on backorder until 5/10/19
Yep I do, that’s what the current eta is. Some are in transit so it might change.Ballin'. Think that date is fairly legit? Can't wait to get my hands on a set
There was a time when cross-drilling (and slots) were created to alleviate gasses that would build up between the pad and the surface, but pad technology has eliminated that. I don't know the history exactly, but I had always been taught this was more the case than for cooling. And then there's also the argument with holes, you lose surface area. The benefits of increased surface area for actual braking outweighs any negligible effect you get from any cooling.My understanding is drilled are better.
That's gotta be (is most certainly) wrong. No way anyone makes a two piece (or even a quality one piece) rotor for this car for $100. If they do, I don't want it, that's for sure.I believe WAGNER Makes gt350 front solid rotors on rock auto 100 a piece
The two different PNs suggests they would be side specific, n’est pa?Are the solid rotors side specific like the cross-drilled ones? Haven't heard if the veins are straight or curved (which would make them L/R specific).
Or F & R peut-ĂŞtre? That's why I asked...it would seem logical that we need two part numbers for F & R if they are not side specific, or four part numbers if they are.
Also non drilled/slotted rotors are easier to turn. Shops complain the drilled ones mess up there bits.
My buddy works at a Toyota dealer and turned my drilled R front rotors after 5 or 6 track days. Pads were completely gone and I got bad brake vibration right in the last session of the last day. Not convinced it wasn’t just pad build up that wouldn’t have corrected itself after new pads, but he offered for free so turned the front 2 and again has perfectly smooth vibration free. I did the math on turning and unless they crack, I could turn 3 times and do 4 groups of 5/6 track days would be about 20-25 days on this schedule before rotors are dead. That woould be nice and 3 years for me. I will switch to non drilled next time if available.
Are others having to turn rotors after a number of track days? How often are you replacing?
Hahahah...it happens!
Man what a brain cramp I had....hope it clears before too long...
