Schwerin
As far as I know its F-series only right now. otherwise the Mustang GT's MPG would have been rerated.I'm pretty sure the 21 F150 coyote does. Don't know about the mustang..
Then why did Ford recommend 5w30 for the same gen 2 engines in other markets while calling for 5W20 in the US? A: They know 5w30 is better but decided to eat a few warranty jobs in exchange for better CAFE numbers.Maybe some clearances were changed to eliminate the tick (oooh, I said "tick"...) and to maintain the same oil pressure it took 5W-30.
Hello; The chase for better CAFE numbers unfortunately makes a sad sort of sense.Then why did Ford recommend 5w30 for the same gen 2 engines in other markets while calling for 5W20 in the US? A: They know 5w30 is better but decided to eat a few warranty jobs in exchange for better CAFE numbers.
If they are specing 5W30 now, its because the value for CAFE is no longer worth the repair costs. Don't know if the value of the CAFE to the bottom line went down or they found out the repairs are more common or expensive than the original guesstimates.
From what I can tell the areas that called for 5w-30 we also all hotter climates.Then why did Ford recommend 5w30 for the same gen 2 engines in other markets while calling for 5W20 in the US? A: They know 5w30 is better but decided to eat a few warranty jobs in exchange for better CAFE numbers.
Back around 2001 or 2002, someone posted an internal Ford document on a forum (Club Focus IIRC). It disappeared almost immediately but it acknowledged that there would be more engine failures with 5W20 compared to 5W30 but most would be after warranty. They had originally wanted to call for 5W30 with 5W20 optional so they could test with 5W20, but the govt said no way, so they had to spec 5W20 if they wanted to test with it. Obviously not about the Coyote, but it did not have any wording implying it was only an issue with the subject engine family.Hello; The chase for better CAFE numbers unfortunately makes a sad sort of sense.
After reading a few posts it seems the owners manual allows for use of 5w30. This is similar to my current vehicles. Both call for 5w30 but allow 10w30 as long as air temps are not too cold. Looks like using 5w30 in the Coyote ought not to void warranty.
Hello; A long way back the gov had rules on fuel economy and decided to have at least two categories. Cars and light trucks. They did not make the rules so strict on trucks for sensible reasons. Back then a truck was mainly a work vehicle used to haul or tow.Back around 2001 or 2002, someone posted an internal Ford document on a forum (Club Focus IIRC). It disappeared almost immediately but it acknowledged that there would be more engine failures with 5W20 compared to 5W30 but most would be after warranty. They had originally wanted to call for 5W30 with 5W20 optional so they could test with 5W20, but the govt said no way, so they had to spec 5W20 if they wanted to test with it. Obviously not about the Coyote, but it did not have any wording implying it was only an issue with the subject engine family.
Hello; Yes, back before the change I could count on getting some better average MPG from the Nissan Sentras I owned. For large trucks the old method was closer to accurate for my driving. I do not know how to compare the new EPA MPG estimates from actual experience. I have read and heard the new figures are closer to real life for non hybrid and non electric vehicles. I just have not owned anything newer than 2004.@sk47 in the 1980’s the epa fuel mileage was calculated differently. The mileage test sequence has changed dramatically, plus they all ran pure gas back then not this watered down e10.
The change was in 2001 i believe. My 2000 ZX2 called for 5w30 but my 2001 was w20. There were 0 engine changes.Back around 2001 or 2002, someone posted an internal Ford document on a forum (Club Focus IIRC). It disappeared almost immediately but it acknowledged that there would be more engine failures with 5W20 compared to 5W30 but most would be after warranty. They had originally wanted to call for 5W30 with 5W20 optional so they could test with 5W20, but the govt said no way, so they had to spec 5W20 if they wanted to test with it. Obviously not about the Coyote, but it did not have any wording implying it was only an issue with the subject engine family.
Was all this confirmed for the 2021 Mustang GT? All I've seen is in the F150, can you link us to where you saw this for the Mustang Coyote engine?Both the f150 and GT are using a belt driven oil pump now, too. That's an interesting change. I guess OPG gears can't be recommended anymore .
I can't stand cylinder deactivation so that part sucks
The 5.0 in the 2021 F150 has it as well as the variable cylinder crap.Belt driven oil pump. where the eff are you guys getting this bogus info from lol
