BillyJRacing
Carbon does have a extremely wide variance in terms of weight, strength, and stiffness. It can also have stiffness engineered into an object in ways that are impossible with traditional metals -all mentioned in the article. Your responses suggest you have not read the entire article. If not, I urge you to.
Carbon, like most other materials, has wide variances in strength and stiffness based upon a huge number of highly variable factors.
I'm just very uncomfortable with the assertion that "carbon is better" and "Carbon is stiffer" as unsupported glittering generalities.
I am absolutely certain that I can design and manufacture a forged aluminum wheel with 100% of any carbon wheels "stiffness " within 10% of its overall mass at one third of the manufacturing cost.
That reason is why carbon has made very little inroads into a share of the wheel market.
Carbon is lighter, yes. It has fantastic tensile strength, yes. But wheels have certain minimum thickness requirements that limit the advantages of carbon.
You have to tell the whole story.
It's impossible to make a forged aluminum wheel to have 100% of Carbon Revolution's wheels stiffness with only 10% more mass. Now i'm sure you can make a cheap, poorly engineered and manufactured carbon wheel that is super flexible and has the same stiffness of your proposed wheel, but you can't match the weight and stiffness of Carbon Revolution's wheel -it's impossible from a material science standpoint.
If you could defy material science, I know a few guys at NASA and the Military that would like to talk to you.
The reason carbon has made very little inroads into the market of wheels is mentioned in the article. CR is the first company to put them on a mass-production OEM. They are also expanding their production 15X (from 10K to 150K a year). You'll see them on more and more cars in the next 5 years.
Absolutely. There's a reason the 5-7 "Y" spoke design is used - because that is the general optimal design for strength and stiffness. However, from a material standpoint, the only way an aluminum wheel can match carbon's stiffness is by being SIGNIFICANTLY heavier.I have some sympathy for @Forgedwheeler though - his point is that while aluminum isn't as strong or as stiff as CF, you can still make a stiff wheel out of it. The stiffness of the finished wheel is determined by the design, not just the material.
The classic racing wheel design with five or seven y-shaped spokes (presumably) produces adequate stiffness in rotation to handle accel/decal forces while providing the best stiffness laterally for lateral g's. Making a wheel out of CF has to be more complicated because the stiffness may well be different in different directions depending how the fiber layers were built up.
Of course, the easiest answer is to build wheels out of the stiffest, strongest material you can find - steel is 6x stiffer and 4x stronger than aluminum but it's only 3x as heavy. Theoretically, an optimized steel wheel could be lighter than an aluminum one.
As mentioned above and in the article, the carbon fibers can be layed in directions to increase the strength in load paths that cannot be matched by aluminum. Then add geometric shapes (hollow spokes) and carbon further stands apart in terms of strength, leaving aluminum behind.
Theoretically, given the same weight, an optimized steel wheel would be barely stiffer than an aluminum wheel but would not have the same strength. Look at the material properties on Page 6.
