terry_b
Technically a Chevy guy
Here are my rear pads and rotors, inside surface. Looks like corrosion caused the edges of the rotor to lift which resulted in an odd wear pattern on the inside edge?
The outside edge looks like you would expect: normal, even wear. Not even really enough pad material gone to justify replacement, but I've got a set of powerstop on the way.
The whole reason I took it apart was that we were having issues with the parking brake. The car started rolling when parked, and the brake handle was locked as high up as it would go. I found the threads on here regarding the adjustment underneath the car and tried it. The adjustment made the handle position tighter, but did nothing for actually holding the car parked.
Would this explain the poor performance of the parking brake? The cables move smoothly, nothing else seems off. We haven't noticed any lack of braking performance while driving, but we probably wouldn't in the rear.
https://i.imgur.com/dKwSkML.jpg
https://i.imgur.com/UkqcKkx.jpg
