Norm Peterson
corner barstool sitter
Because while you have direct control over the direction that the front wheels are pointed in, you do not have that "luxury" where the rear wheels are concerned.I keep hearing this over and over again. And I'm sure all manufacturers believe it.
But why on Earth should understeer be any safer?
Understeer is inherently self-limiting, where oversteer is self-energizing at least to some degree. I'm not talking about oversteer caused by a too-anxious throttle foot here, because a car in that scenario could well be inherently understeerish (heavily so, even) and you blew through rear tire grip via the vector sum of lateral plus longitudinal grip requirements.
Understeer by reason of over-driving. Driver error.I hate understeer. There's nothing worse than plowing straight on with the front wheels completely out of control.
I have my doubts that your car's understeer budget math would call that situation 'oversteer'. Closer to neutral steer, maybe.Recovering from oversteer is easy-peasy, just dial back the gas a little and turn the steering wheel towards where you want to go
If it was true oversteer that was threatening to get out of hand, you wouldn't dare to even breathe off the throttle, as even a little forward load transfer would plant the front tires even harder relative to the rear tires (which would be losing vertical tire load at the same time). Chances are you wouldn't dare to add throttle either (that pesky vector sum thing). If you've never been there, its neutral throttle/maintenance throttle + prayer time.
Norm
